So i've had a home built system for about 10 years now centred on the 4770k and I feel it's time for an upgrade
It's water-cooled in a corsair 750D case. Reservoir & pump combo is a front bay mounted XSPC unit D2 XSPC X20 750 with 1x 140mm, 1x 280mm & 1x 420mm radiators.
I have a Dell S2719DGF monitor - 27" 1440p 144 Hz that I'll be using and don't need a keyboard mouse or Windows and I was thinking of keep the watercooling & the case too.
I'd like a recommendation of a MB, CPU + Waterbock, RAM & Storage (I have plenty old drives, both HDD & SSD, but I am sure a new unit would be better than reusing on old drive for the OS)
Also recommendations for a 'starter' air cooled GPU to keep me going till I upgrade the GPU to one with a waterblock in a few months time.
I've been away from the PC building scene for years and have no clue on what's what..
I play mostly Assetto Corsa with a bit of Battlefield & other FPS now and again.
Total budget for now is 100-1200 for the above,
Thanks in advance,
Thanks in advance,
