Upgrading help :)
13 Jun 2009
Northern Ireland
ok, thanks sharlaw.
EDIT: Just wondering if anyone could spec me the following:
(for gaming, along with my 4850)
A decent processor
A decent motherboard
4GB Ram
Decent PSU
For around £350? possible? my budget is a bit flexible
AMD Phenom II X3 Tri Core 720 Black Edition 2.8GHz (Socket AM3) - Retail £109.99
(£95.64) £109.99
(£95.64)
Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express DDR3 Motherboard Gigabyte GA-MA790XT-UD4P (Socket AM3) PCI-Express DDR3 Motherboard £107.99
(£93.90) £107.99
(£93.90)
OCZ ModXStream Pro 600w Silent SLI Ready ATX2 Modular Power Supply OCZ ModXStream Pro 600w Silent SLI Ready ATX2 Modular Power Supply £64.99
(£56.51) £64.99
(£56.51)
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel (OCZ3P13334GK) OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel (OCZ3P13334GK) £46.99
(£40.86) £46.99
(£40.86)
Sub Total : £286.91
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 15% VAT : £44.54
Total : £341.45
how is the Tri core for performance? i'm a nooby overclocker so would probably be running it on stock speeds, with a 4850 would it run all modern games to a decent standard?
Yeah it would, i used to have the 4850. One of the best cards for the price. although if you're looking to play games at a high resolution then the Gainward GTX 260 is the way foward.
4850 is fine at 1280x1024 or lower resolution if you game higher then pay a bit extra and get a 4870 (very cheap for the performance at the min).
