After my PC died on me (suspected storm damage), I am upgrading from an Asus Z170-Pro and Ian i7-6700k @ 4.6GHz to an Gigabyte Aorus Pro with an i7-9700k @ TBD.
For now I will transfer my other parts across to the new board. (32Gb Corsair vengeance 3200MHz, Water Cooled Sapphire Nitro+ RX480 8 Gb OC).
This is built in an Enthoo Primo, with an EK CE280 rad in the base, with EK Vardar EVO 140ER fans in push/pull, and a Hardwarelabs Nemesis 280 GTS in the roof with Nanoxia Deep Silence 140mm 1100 rpm fans in the roof in a push/pull configuration.
The idea being that the GTS cools actively whilst on idle/low load whilst the CE280 cools passively.
As the CPU load rises, and the water temp rises the CE280 kicks in progressively.
My aim is quiet performance for VR Racing games.
The question I have, is are the radiators in my system up to the demands of an i7-9700k, which may be slightly overclocked. If the answer is no, what is the best bet? Adding a 420mm radiator in the roof to replace the 280gts, or just add a 140mm radiator in the rear vent position, or in the roof?
