I reconfigured the fans last night to lower the noise.
I.removed the Nanoxia Ultra quiet fans in push/pull and replaced them with two Noctua NF-A14 PWM. It is quieter as the Nanoxias were spinning at 1100 rpm all the time, and I have the impression they don't like being used horizontally due to the rifle bearing.
Stable idle water temp was 27 degrees. With max load temp rising to.32 degrees. I hope the XT45 420 will either drop the temp, or the noise slightly.
I still need to reconfigure my fans as I have some radiator fans running on the CPU header. Seems pointless, as I don't need them to ramp up based on CPU temp.
