- 12 Jun 2011
HI all,
Im looking to upgrade my CPU and motherboard. My machine was originally a gateway GB5092b
spec here
http://support.gateway.com/s/PC/R/1014956R/1014956Rsp2.shtml
however this has been rebuilt and i now have a corsair 880d casing new GTX580 gpu and also maxed out the M/B with 8gb (4x2gb) ddr2 ram.
also have 4 hard drives. solid state for the o/s and another
4gb from the other drives. I also have a water cooling kit going to the CPU.
anyway my current processor is a intel Q6600 quad cpu @ 2.4ghz.
i would really like to upgrade this to a intel i7 (one of the higher specs i7)
im not bothered about over clocking it etc..
i know i will need a new m/b as the i7 uses a different socket but looking at the i7 i see there are 3 socket varieties 1366? 1155? 1156?
which is the best processor / socket to get? also i would like a m/b with at least room for about 24gb ram
also with the watercooling kits will these only fit on certain processors / sockets or do they tend to be universal?
thanks
spec here
thanks
just rebuilding the OS now (didnt realise that when changing hardware the existing OS wont boot once hardware has been changed
so had to backup favs, emails , documents etc.. (drag..) anyway really chuffed with the new CPU and board.
