What transcoding software are you going to be using by the way?
Quick Sync won't work with Badaboom.
Then you should have stated you were using V2.0. You noted what version of Mediaespresso you are going to use, and so I simply assumed you would be using the first release.
Then why did you say what version of Mediaespresso you were using?
And how have you caught me out?
Because you though I was talking to version earlier that 2.0.
