Upgrading soundbar, worth upgrading TV at same time?
7 Nov 2005
Widnes
I currently have a 55" LG B7V and Yamaha YSP-2700 soundbar. It's in a 6x6m living room and I mainly stream TV and movies via AppleTV with some small amounts of gaming and sports.
The Yamaha is starting to get more frustrating so I'm looking to upgrade to the Samsung Q990C. I don't really need to change my TV right now but if there's special offers on...
TV wise it is between the 65" LG C3 and Samsung S90C. Would have the TV and soundbar the same brand help in any significant way with audio sync? Even between apps on the Apple TV I seem to have different sync issues - think it is the audio format disagreeing with the Yamaha. I was edging towards the LG but the Samsung would be £200 cheaper and it being the same brand in case there's any additional integration benefits.
Are these upgrades worth it? Will I notice a difference?
And the real one for debate - C3 or S90C?
C3 and S90C are both excellent, can’t really go wrong. I’d just go for whichever you can get the better price on.
55 to 65 will be a big difference, IMO.
I don’t know anything about soundbars really. I use Sonos and have been very happy with them.
I don't know how prices compare generally elsewhere but Richer Sounds currently have £350 if you buy an S90C and Q990C together, making it £1878 for both.
Why not add a decent speakers ;-)
In a couple of years you'll have the same issues with new soundbar. With that system when the AVR goes out of date (will probably take 15 years so upgrading is a must by then) then just change the AVR
Another thread successfully **** on, barely half a dozen posts in
"Should I buy S90C or C3?"
bUy a MorE eXpeNsIvE AV sYstEm
:rolleyes:
How's that E-ARC codec support ?
"The Samsung S90C supports all Dolby Digital options flawlessly. Unfortunately, it doesn't support DTS formats at all, which is disappointing, as many UHD Blu-rays use DTS for their lossless audio tracks.6 D"
absolute fail. Buy a soundbar with all the codecs, use E-ARC to gain ease of connection, and DTS doesn't work. What a joke.
Won't have that issue with AVR, as long as your source goes into the AVR first
The LG C3 is slightly better, as it supports DTS-HD Master 7.1 but I don't think the S90C does
Exactly. reason to go for the LG. Although I have had issues with E-ARC myself, with LG, unsure where the problem is, so have choice of falling back to devices through av pre amp.
With soundbar if it just has single E-ARC input, you are stuffed. Combination of HDMI inputs and E-ARC is ideal on soundbar, to get around any possible E-ARC sound issues, or PS5/Xbox VRR 4k 120hz etc if your soundbar HDMI in doesn't support that, so you do have to use E-ARC for those console devices.
A fantastic example of you missing the key parts of people's post in your increasingly tedious campaign to make everyone spend loads of money on AV systems they don't need or want.
So you read this and fixate on whether eARC supports DTS, a format that last time I looked, AppleTV doesn't support in the first place anyway.
Why not add a decent speakers ;)
Don't you need to run wires everywhere? I don't need to do that with a soundbar. I don't want to have to hide speaker wire under carpet or round door frames. I used to have a more basic 5.1 system (certainly wasn't >£1k) but the wires really made things awkward. I'm not an audiophile so the soundbar was a good fix. Mainly to get better sound than the TV speakers.
Due to the way the wiring is done for my TV (through the wall), I tend to feed the source directly into the soundbar and then run the HDMI up to the TV from there. This will only fall over if I got more serious with gaming and needed higher refresh rate than the non-2.1 HDMI ports the soundbar will allow.
Although have I have drawers full of blu-rays, I haven't switched on the PS4 for agesss - just end up streaming instead. Previously had the Fire Stick 4K Max and now moved to Apple TV 4K.
I have been looking at the Q990C it gets really good reviews and now the D variant is out it’s dropped in price a nice chunk.
Did you get one in the end ?
so give up any dts content from any source? my god you lot make me laugh.
Not on a Samsung 990C you wouldn't, you can just plug a Blu-ray player or whatever directly into the soundbar itself and get DTS that way. TV doesn't need to support it as you are by passing it.
Also, serious question, is there an actual reason why you can't post a picture of your system...? You're always quick to tell everyone to buy an AVR and speakers on threads like these but never respond when people ask why. I'm not flaming or having a go, would just be nice to know the actual reason rather than see the constant fairy tale posts go up.
While it's very expensive with the subwoofer, the new Sony Bravia theatre quads are really decent. They've basically made it what the original should have been like, so much so that it can actually hold its own against some entry/mid range separates systems and I actually bought the system myself after having a demo of it.
