if i want to upgrade to a 144Hz monitor does that mean i need to have my fps at 144 too?
im currently getting between 60-90 fps, would i see a benefit from a better monitor?
also, is it a noticable upgrade or not really?
It depends, are you currently using a monitor that has freesync/gysnc? What GPU and monitor do you have?
i have an older AOC 27" 1440 IPS screen. With a 2060 super.
thinking about an LG27GL850
Get an LG C9/X, its only 120Hz but has the size and superior panel going for it. GSync compatible.
IT makes me sad not getting 165 fps in games when i have a 165hz monitor...
The increased hz will make your gaming better even if you can't hit 144hz, by reducing tearing.
They are not the same, however in these cases they are intrinsically linked. You will get 500+ fps sure, but your monitor will only be able to draw at a frequency(hz) of 1 frame every 1/75th of a second, therefore anything above 75fps you won't see.hz does not equal fps its a common misconception. Its not the same thing at all. You cant "hit 144hz" your monitor is 144hz, static, it doesnt change. FPS changes dependent upon variables such as speed of your machine, speed of graphics card. HZ is the refresh rate of the monitor its static. Faster refresh produces a smoother picture.
Hence why I can run an old 3dMark 2006 benchmark and hit 500+FPS on a 75mhz 1440p Monitor.
