- 27 Jan 2012
- The king of the north!
Will be fine
just keep the tubing runs kink free
, very unique. Not really a way around it i dont think. The EK Bridges are quite restrictive themselves. Ive tried one on mine but run 13mm ID crystal link tubes now. So no It wont be any more restrictive.get some spacers machined? Can't cost that much. Else bend some funky hardlineyep it's incredibly annoying, was so angry last night, just the fact I've put so much time and effort into planning everything. I've spoken to guys at EK many times regarding the blocks and the bridges needed and they assured me, as did the EK configurator, that everything will bolt together just fine. Clearly something is different with the MSI 390 as the blocks are just way to short, they should not be under flush of the edge of the PCB. With them that short, there is no way any bridge will connect, and there is no way any EK fitting will screw into the top because it fouls on the edge of the PCB. Yes that's fine for running one card as you can come in from underneath, but not when running multiples, but the EK guys knew I was running multi gpu's they suggested to bridge and everything that's the frustrating bit.
I mean, this is the block from above, there's no way of any bridge fitting for the card, yes the block fits but it's not how EK show when running multiple cards.
as you can see, can't even connect anything to the top holes
Only thing I can do now, is fudge around with the loop, and make it functional by doing something unconventional and not how I want it. There's no way I can connect to the tops of the card because everything will foul the on the PCB, so I'll have to plug the top holes and connect underneath, like this I guess
You shouldn't do it that way. The Thermosphere has a dedicated in port (RH side) as it has a built in jet plate similar to a cpu block. If you run it that way the top card won't be cooled as well as the bottom card.
because I bought the GPU's way before I decided I wanted to go to a water cooled setup.
Well lets hope I fail in providing you a train wreck. Thanks for your nice encouraging words.
What tubing are you going to use ?
