I have recently upgraded my motherboard (second hand), CPU (second hand) and memory (new), however I am now having USB external hard drive problems which I didn't have before.
I mostly use Teracopy to copy/move files, but since upgrading it fails most of the time on the verifying stage when I copy from internal hard drive AND external hard drive.
I have the external USB3 hard drive in 2 partitions.
I have tried 2 front USB ports (USB3 & USB2).
I currently have it on the rear USB3.1 port and the problems of momentarily disconnecting happen on all 3 USB ports.
I have run a surface scan for and there are no errors. I am currently running a bad sector scan which if the program is accurate reports 1 bad cluster. All my drives are in very good condition and although a few years old now still appear to be in very good health until now with a change of motherboard, CPU and memory.
When I copy onto the external USB hard drive there are occasions some files will not be copied but mostly it seems to be when Teracopy is verifying, Bart Backupper program also reports errors sometimes.
Winamp which I use for music sometimes reports that I have just plugged in my external hard drive and would I like to use with Winamp due to this error.
The previous owner of the motherboard flashed the bios and it’s date is 13/11/19 (American Megatrends Inc. – Version = 1.NU AMD Agesa Combo-AM4 1.0.0.4).
I did have a problem where my external USB hard drive didn’t show up in the boot menu but that was just once. Upon the first install on Windows 10 it hot to the stage of copying files and then aborted itself. when I booted Linux Mint (Live distro) it hung and I had to restart the computer.
I have reinstalled Windows 10, I have updated the USB drivers and annoyingly the problem persists.
Does anyone know what the problem is with my computer?
Thanks.
My system spec is:
Operating System = Windows 10 Pro 64bit.
CPU = AMD Ryzen 5 1600 – 6 core, 12 threads - (Recently upgraded, Second hand)
Motherboard = MSI X370 Gaming Pro Carbon - (Recently upgraded, Second hand)
RAM = Corsair Vengeance LPX 16GB (2x8gb) DDR4 3000 MHz C16 XMP 2.0 - (Recently upgraded, New)
PSU = Corsair VX450W PSU
Graphics Card = Nvidia GTX (Inno3D) 1060 6gb
Audio = Sound Blaster Z
Hard Drives:
SAMSUNG SSD 830 (128gb) – Sata
Samsung ST500LM012 HN-500MBB (500mb) - Sata
Samsung M3 portable (1tb) - USB3
Blu Ray Recorder = LG HL-DT-ST BD-RE BH16NS40 - Sata
Thanks.
My system spec is:
Hard Drives:
