usb memory stick - thread
Caporegime
8 Sep 2006
On Ocuk
Basically i've got over 30gb of old skool retro gaming stuff :p what memory sticks for a good price would you recommend?
Can you get 60gb or larger?
Thanks
p.s Are external hard drives worth looking at?
If your motherboard supports DDR3 whcich I think it does (Z68X-UD3P-B3?) thne get a usb3 pen drive as it will be much quicker to transfer all that data.
THIS has pretty good specs.
Not sure why it says
- Capacity: 32GB in the product description though, must be a typo!
As for external hard drives, they would be a better option for transfer lots of data but pen drives are less hassle in my opinion.
Then again would an ssd be a viable option?
I have a USB3 caddy from OCUk for about £12 and use variously SATA laptop drives and SSD drives.
So by spending on a cheap SSD for about £30 and the caddy, you have a large flash drive.
Seagate 1Tb Expansion Portable Hard Drive
Ordered, had to pay it weekly which was a bit more expensive in the long run but cheaper in the short term. Can't say where!
