USB pen drive write protected
18 Oct 2002
South Wales
I have a unbranded 2gb usb drive and it has a 499 mb write protected partition on it is there anyway of getting rid of it ?
I have tried low level format and few other tools from the net but nothing has worked yet :(
Personally I'd use a gparted boot disc (there may be easier ways in windows but gparted is reliable as hell) and just delete it.
Ok fair enuf but where how etc ? not heard of it before now :o
Did that program works great but still won't delete the 499mb partition.
It's taking the mick now, I found out that it is a smart notebook student edition usb drive so the 499mb is the smart bit.
Try the Windows diskpart utility - first fire up a command prompt (as administrator), then:
diskpart
list disk (make a note of the disk number which corresponds to the USB drive)
select disk # (where # is the USB drive number)
clean
exit
Then go into Control Panel > Administrative Tools > Computer Management > Disk Management, and create/format a new partition on the drive as normal.
Needless to say, be *very* careful you've selected the right disk before issuing the "clean" command, or there will be much sadness...
diskpart
clean
exit
Thanks just done that and the result is :
"Diskpart has encountered an error :" "The media is write protected."
See the system event log for more imformation. :(:(
Done that as well and i'm still getting the message :
Bloody annoying now :mad:
These are things I have tried so far :
searched for a switch to the point of ripping it apart ;),
there is "NO WRITE PROTECTION SWITCH"
tried to format (quick / FAT32) = the disk is write-protected
tried to format (quick / FAT) = the disk is write-protected
tried to format (not quick / FAT32) = the disk is write-protected
tried to format (not quick / FAT) = the disk is write-protected
tried to format via DOS = the disk is write-protected
tried tools (i.e onBeley,other low format tools) = the disk is write-protected
tried the regedit fix WriteProtect DWORD value 0 = didnt worked
tried Microsoft© scanDisk™ = the disk is write-protected
tried Microsoft Defrag Tool = the disk is write-protected
tried everything on many computers with xp and vista = the disk is write-protected
reinstalled windows,on the 1st boot,i tried all of this = didnt worked
tried all of these things with restarts and re-connecting usb = didnt worked
i can access/copy/Read data but i cannot "Write" anything on it or delete the partition.
PLUS i've done all of the above suggestions... :confused:
I have had pen drives with this before and always managed to sort them out with one of these, but this is a nightmare. :eek: :mad:
reinstalled windows,on the 1st boot,i tried all of this = didnt worked...
wow... your dedication in getting to the bottom of it is admirable, but I don't think I'd bother reinstalling Windows for the sake of a no-name 2GB flash drive.
Maybe it's been hardware set to be read only, without a user-accessible switch if you see what I mean. I did find this after a bit of googling, could be worth a shot (you might need to do an additional "normal" format afterwards, if in fact it works).
If that doesn't work, just stamp on it, that way it won't bug you any more. :D
I know aren't I good :D I think if this next bit don't work is i'll hide the 499mb partition and use it as a 1.3gb stick :D least that way i'll get some use out of it.
Thanks very much for the help yer a gem ;)
http://www.dban.org/
Try boot and nuke, but remember to disconnect any hard drives first :)
I'll give this a go too nothing to lose :rolleyes: only the last 3 days :D:D:D
Welll that's it I give up, tried it all and even boot & nuke didn't do it just couldn't recognize that part of the drive.
Thanks to all especially CaptainCrash top bananna!! :D
Don't give up! :)
I reckon you will stand a better chance of removing the partition if you find out which controller your USB flash drive uses. To do this download and run ChipGenius from here. This should tell you the manufacturer and include a link to the corresponding mass production tool which enables you to reprogramme the drive inc. wiping it and removing any write protected partitions (particularly those annoying CDFS ones) etc.
If you don't have any luck with that, check the FlashBoot website.
conoflex vs flash drive!! The battle of the century!!
I'm rooting for you to fix it. Don't give up! :D
Edit: is this it? What is it for anyway?
ChipGenius keeps giving me a runtime error 5 all the time (run compatability mode administrator etc)
Flashboot is a good site if I could read Russian :D even in trans lation I can't find a program that will do anything.
found a usb checkdisk 5 prog and that doesn't see the partition I want to remove it does say this :
VID&PID: Vid_3538&Pid_0059
Speed: high speed
VendorID: Smart
ProductID: Notebook SE
Product Revision: 0.00
