- 30 Sep 2005
Has anyone had the issue where you connect a USB3 HDD into a USB3 port with a USB3 cable after you have installed the USB3 drivers but have it only work at USB2 speeds
To make matters worse Windows keeps bringing a box up saying "you have a USB3 drive, you will get better performance if you plug it into a USB3 port"
yeah, thanks Windows
BIOS is all set for USB3, it worked once btw
