Permabanned
- 10 Nov 2005
You see dearest @bigmike20vt our Jon's somewhat of a low key rebel you seeYup, guilty as charged your honour.
He secretly has a fetish for failing someone elses emissions at work for not having a cat or a knackered one, giving them a stern talking to about save the dolphins/3 degree planet, and then driving home after work without one himself then sneaking it back in when he retests it come MOT day
What was that old saying "**** the whale, save the V8!"
Yassss! In the bin it all goes then, nice bit of weight saved from that pump, 4 times I've had ABS try to kill me, at normal speeds braking normally, and at nearly stationary speed sliding forwards at 5mph after braking for a roundabout, instead I ended up slowly entering the roundabout. Ridiculous. On black ice with the pedal flat to the floor doing nothing!You can fully remove all the ABS components and it'll pass, but only on cars registered before Jan 1st 2010.
Hence always disabling it.
Also, if you're drifting and spin out and go backwards you can't brake thanks to ABS on old cars! So you'd never want it on a drift spec track car that you drive on the road as well.
Old car ABS is literally dog ****
