This may sound a bit silly but how do you actually use a punch bag, do you just randomly punch it for as long as you can?
Or do you have some sort of routine.
You can do a circuit, e.g. 10 punches, 10 press ups, 20 punches, 20 press ups, 10 punches, 10 press ups etc
dark_shadow said:At the gym (pre-falling ill) we had a board numbered 1-10 which compromised of combinations such as:
1 - Jab, cross, jab
2 - Jab, opposite hook, uppercut
3 - Jab, jab, hook
4 - Jab, cross, jab, cross
5 - Jab, left hook, jab, let uppercut, right hook
And so on . . .
This compromised of 10 bags at 3 Minutes each. After a 3 minute bag, the timer would beep for for the last 10 seconds, which was what we call the 'Knockout' in these 10 seconds you give it your all, which gives you the advantage near a knockout, hence the name. After a 3 minute round the timer gives a minute break, during that break we did either: Press-ups, Sit-ups, Burpees, Squats, Skipping and so on . . .
Try a dedicated boxing shop etc . . .Crispy said:does anyone know of where I can get a timer I can set up to beep at intervals to do something like this at home - I need the structure to keep me focused!
