It may well do, but how is 6ch analogue line-level bass management processor designed for SACD and DVD-audio players relevant to the OPs requirements?My outlaw icbm-1 has some nifty lfe redirection methods.
Odd phrase. Quite bizarre. Even Google is stumped.not so missile shaped ....
Detail, yes, which you seem to need, but we don't.a hell of as lot more detail ... you know the saying once you stop learning ... google that
I did read out of courtesy, and yes, I noted the exception. The difference between you and me is that I understood the context of the exception. I also understood how that would apply, or more specifically how is doesn't apply in @TALON1973's case. I suspect you didn't.if you read it you know an exception was listed ... was curious if you'd read it
Glad you were able to come to a decision. Good luck, and I hope you enjoy it.I'd like to thank all those that have contributed to this thread. Much appreciated.
I think I'm going down the Onkyo TX-L20D route. While I have extra speakers that I won't be using I quite like what the onkyo does. And has things I hadn't really considered as options before.
Because it may solve the issue at hand, as it does have a lfe mix feature. So if he can send multi channel it may mix in lfe into mains without discarding, then send that to 2ch amp.
It may be convulated but it may work. I wouldn't it or recommend it, but it's possible.
Would need a dvd/bd player with 5.1 out, outlaw icbm-1, and a stereo amp.
But not relevant to the OP's enquiry unless you know for sure that they own a 4K player with 6ch out.
Lots of things are possible in theory, but let's try to stick with the practical when dealing with enquiries unless an OP requests otherwise.
Lol... Sod's Law. You must have posted after I started a reply to @hornetstingeryou missed my post before you lucid.... I do have the panny ub820 ... although tbh as I wasn’t thinking 5.1 I never mentioned it. And as it’s been so long since I had 5.1 I forgot the ub820 has the outputs .
ICBM aren't common over here. I used.it as high pass between pre and power.
But if it can function to remix in the lfe that would otherwise be discarded maybe uwrufl for someone who doesn't want a avr but wants to retain lfe
Just as he would have done with an AV amp/AV receiver configured to drive a 2.1 speaker package. In effect, that's what the Onkyo TX-L20D is; it's av AV receiver but missing the centre and surround channels.He/Talon is going to benfit from LFE, being decoded and mixed in, anyway, with his judicious choice of Onkyo TX-L20D...
hdmi in , dts decoder, 2.1 and it's manual says he does
The manual says that the ARC functions the same way as your Beam i.e. the sound from HDMI sources to your TV gets passed to the TX-L20D. There are a couple of things to check. First, your TV is ARC compatible; which given what you said about the Beam should certainly be the case. Second, that HDMI CEC (HDMI control) is switched on in both the TV and the Onkyo. The default value is OFF with the Onkyo out of the box.
HDMI CEC should also fix the lip sync issue with the Panny. Make sure CEC / VieraLink is enabled in the Panny too.
Did you check - or did someone who made the recommendation say - that the set had Dolby Vision?
