- 6 Jun 2011
It damages the springs in the bed
I would say it depends on the type of mattress
You shouldn't need to fold it in half if you have a reasonable size estate, just bend up at the edges maybe.
ikea sell rolled up mattresses these days (granted probably not the cheap metal spring jobbies).
Very true but mine wouldn't be possible . Too expensive to replace if broken
THREAD RESURRECTION!!!
So, my brother needs to shift a super-king matres and divan set. Looking at the above calculator, it would seem a SWB Transit or Vivaro should do fine.
Think that'll be OK?
dogging?
I've just hired a Vivaro to move a bed. The load bay will certainly be long enough. But with a superking width might be an issue. You will probably have to have the mattress on the diagonal which isn't ideal. I would be inclined to go to the next biggest van which will probably be much taller inside letting you stand it up more easily.
Im pretty sure it was a king size we managed into a Civic Type S.
It wasnt transported entirely flat![]()
My first 'car' was a 17cwt Bedford with a double mattress in the back![]()
Our £1000 mattress got 'folded' into a car. No damage done. Clearly you wouldn't want to keep one folded for a long period of time.
