Vehicle inspection help please
7 Apr 2009
Greenock, Scotland
Im looking at a 2nd hand car and Im considering getting a vehicle inspection done on it. Never had one done before so just looking for advice on where to go and what price to pay. The car is a 2009 Mazda 3. I know rust is probably the main concern and thats the main reason for me considering an inspection. Thanks
We used carexamer.com when we bought an older (1997) campervan last year. Really impressed and put out minds at ease. However, this was ~£200 on an £8k purchase and being a lot older, and being a campervan had quite a lot more to well, inspect! Assuming the Mazda is worth £2-3.5k I dont know if I'd pay for an inspection and would be more focused on checking service and MOT history (can check MOT free online with just the numberplate) and getting one of the text check things done telling you if its been written off/nicked etc.
The AA offer superb vehicle inspections for a cost.
They’re a lot more comprehensive than an MOT, but are more expensive.
AA, couldn’t recommend enough.
They checked my old e38 prior to sale and my current V70, both reports were spot on.
I do inspections at large car supermarkets and get asked a lot what cars people think they should buy, and Mazda is one I’d recommend, along with Toyota, Honda, Kia, Hyundai & others.
Ok, they’ll not set your world on fire, but if you want a car that works and does what it says on the tin..
Can anyone tell me what generation the one I linked to is? Thanks
Second gen. As with most Mazdas, look for rust/corrosion. Their wheels are especially bad for it; I had a first gen 3 Sport, my parents had a first gen 3 and a currently have a third gen 3, and all of them had/have issues with corrosion on the wheels.
I maybe be going to have a look at it tonight. The only thing worrying me is that it will obviously be dark and I wont get a proper look at it. I will take a torch with me. Its actually up in Glasgow. I've looked at about 5 Mazdas already and all of them had corrosion on the wheels to some extent a few where pretty bad. How can I determin if its just surface rust or worse on the sub frame?
Unless you know exactly what you’re looking for, it’s going to be tricky.
May be worth looking online to find any pics of heavy subframe etc corrosion on that specific model then compare.
But do bear in mind that the underneath of a car is not classed as cosmetic and do expect to find various suspension parts corroded (it’s very very common). In fact, i doubt any of the thousands of 3 year old cars I’ve MOT’d have been rust free.
I really wouldn’t be concerned about corroded wheels, it’s cheap enough to refurbish them these days.
Inspecting at night isn’t great, as you can’t accurately see any variations in paint colour (accident damage), but if that’s the only time you can do it, then use a powerful LED torch and check panel gaps and down each side of the car for panel straightness (if it’s had a botched repair it’ll be easy enough to spot).
And if you can, do drive it, and don’t be afraid to ask questions.
Thanks very much for that. The car has no paperwork with it. Is that enough to not bother going to look at it?
Well I cant make it today anyway. Think I will give it a miss then. The lack of paperwork disturbs me
