I am an overclocking idiot, but can't you just under-clock the cards memory?
Yes, You can but you'd just be wasting your time. This was my first thought before I knew more about what I was doing. Thinking, well obviously if I'm overclocking the memory, the memory will just run hotter, right?
But actually, even lowering the memory to -502 (The lowest MSI Afterburner will possibly go) all you end up doing is maybe losing a few degrees but your hash rate will absolutely tank. I mean If that works for you and your happy
with the tradeoff from 94MH/s ish hashrate on a 3080 to about 76MH/s for the gain of about 8c at the absolute very best even with a desk fan blowing on it, then sure go for it.
But running Nicehash's recommended settings and using an open air case and deskfan blowing like this gives me 94MH/s.... VRAM right now is 78c, but the desk fan is on it's fastest setting. Was looking at maybe an air con unit to help as summer approaches.
Read here for Nicehash's optimum settings (Recommend afterburner over EVGA Precision X1 as I seem to get lower hash rate with the same settings...)
NVIDIA RTX 3000 series Overclocking Guide to Increase Mining Profits | NiceHash
And this is how I have it set up, only temporarily though. When gaming I just put the fan aside and panel on. I clean it weekly. Air conditioning is next as having the windows open all the time means dust...hair....bacteria....grime....mould... all sorts.
