edit: those Atom boards include the CPU??? for £45???? :O
entireweb - I have been considering buying an Atom but my one reservation is that S3 doesnt work! Have you tried S3?
Thanks in advance
Samsung... most use 6W in the pages I've seen.... tell me tho about your G4 Mac... whats the speed like unRARing say a 4.5gb DVD? I'm wondering about a Mac mini for download box. The LS is great but it takes AGES and I mean IceAges to unpack a 10gb download!!
wow I havent followed the atom very much I'm really tempted to try and get one. my home linux server burns up to much electric for my liking. £45 thats a steal.
I mainly copy the files off the mac mini and do the un raring etc on either my HTPC or office PC. But unraring a 700 mb takes a couple of minutes. So I guess a 4,7 gb would take 15-20 minutes.
But the Mac mini (Mac OS) has a serious flaw, which is why I have moved to the Atom, and that it can only read NTFS drives and not write. It can write to fat 32. But fat 32 doesnt support files sizes over 4GB. Which rules out 720p /1080p mkvs. I had a 500gb usb drive plugged into the mac mini and couldnt copy mkvs to it without doing file splitting, which was a pain.
OSX has NTFS support in about 3-4 ways I found... Fuse is one..
Problem with the Atom is that the 945 chipset motherboards used have a TDP that’s ten times higher than the processor’s, at idle an machine using an Atom on a 945 chipset motherboard is going to use 10W more than a C7 Via platform machine of otherwise identical spec. So for now don't buy atom for power savings alone.
Why do you need to use NTFS on mac mini anyway? Just use ext2 and if you need to read those drives under windows for some reason there is Ext2 IFS For Windows...
