laissez-faire said:It is IMPOSSIBLE to accelerate much faster than mavity with tyres.
Anyone with A-Level mechanics can work this out. Maximum coefficient of friction between normal tyres and tarmac is 1 (and that is pretty damn hard to achieve) and so doing the maths the theoretical maximum acceleration perpendicular to mavity using friction based propulsion is g itself.
C/F = 1 means that if you push at the side of it with a force equal to the weight it will only just be on the 'verge' of moving. Obviously unless it is glued down it is impossible to get a greater C/F than 1 therefore. Incidentally this is why without wings it is impossible to pull more than 1g in the corner otherwise the car will simply slide which is why I always laugh when people claim they pulled 3 or 4, yeah right mate - keep dreaming!
HOWEVER The reason some cars (i.e. F1 cars) go slightly quicker than this is becuase by the time they reach 60mph they are already pushing down quite a lot of downforce, and also the tyres literally DO act like glue by having a hot sticky surface, some of the tyre actually lets left behind when the wheels slip a little. Anyway this is why if the wheels spin a tiny bit the coefficient of friction is slightly greater than 1 and you pull away faster. (So now you know the Physics of why racing driving starts spin the wheels a tiny bit!) However the tyres on an F1 car last about 80 miles...
Obviously with rocket power you can go faster...
Anyway so basically, for a normal road car where you don't want to be leaving black 11's , even with infinite power, 60 mph = 26.8224 m / s => min a = 2.73 seconds.
Concorde Rules said:I somehow doubt its better than a Veyron. It took VAG a few years to get it to work properly.
Which would I have? Veyron![]()
Kazzan said:Anyone with greater than A-level mechanics knows that A-level mechanics is a massive simplification of real-world physics and is actually only applicable in text-books and poorly written computer games.
Friction is an insanely complex force to model, and you haven't even considered the effect that the mass of the vehicle has on its ability to put the power down.
laissez-faire said:You mean like 2 years into a degree in the Physics? Or the maybe Professor who explained it to me?
Are you kidding me about the mass? It cancels out! It puts more force down, of course, but that just means you have more to shift sideways!
Personally, I believe Koenigsegg have the greatest chance...VW won't let them near their mahoosive straight thoughFusion said:I love it how people and the press are just waiting for something, anything along to come along and beat the Veyron in some aspect. A number of manufacturers may make claims, but can they verify them?
That's because nobody was really trying. At all.It took a few years for McLaren to be removed from their performance perch.
No - it took VAG a few years to get it to work properly...and be reliable for more than 5,000 miles.Concorde Rules said:I somehow doubt its better than a Veyron. It took VAG a few years to get it to work properly.
F1 cars are far from fast in the scale of things. Remember that they are built to a very restrictive set of regulations...oweneades said:0-60 in 1.67 seconds?! BS to be honest. With that power it wouldn't be able to get enough traction to do that. Not even F1 cars can do that (I believe they are around 2.5 seconds to 60).
It's all a matter of gearing, power and aerodynamics. To go fast you need to overcome frictional drag (tyres on the road), aerodynamic drag and mechanical drag (the gearing itself). To overcome these, you need power.The top speed would be sceptical as well. With so quick acceleration keeping it in a straight line would be bad enough. I highly doubt it would be able to do 270mph.
penski said:F1 cars are far from fast in the scale of things. Remember that they are built to a very restrictive set of regulations...![]()
Freefaller said:I think there was a 5th gear episode where they did a 1/4 test with a ducati and an F1 car - the bike was quicker off the mark everytime, until the aerodynamics kicked in on the F1 car and it nailed the bike.
Arc said:And their built to go round corners, not simply do a 1/4 mile straight drag, so along with the restrictive regs you end up with cars that are only really geared for about 220 to 230mph at the most.
A bikes always going to win off the line, its just down to its relatively low mass.
