Vista / IE Problem
5 Oct 2004
When I try to log into a router using IE I'm having a real problem
The first time I try to log in I get page cannot be displayed, if I go to the address again straight after then I get the login box.
Once I am in it is very sluggish
My XP laptop also running IE7 is much better
The routers are drayteks but it is also very slow when using Cisco SDM
I tried removing java in case that was causing it but it made no difference
anyone got any ideas?
Have you got a proxy set?
