vista installation problem
9 Aug 2007
vista wants to save to HDD but it says drivers aren't available and to enter disk with them on... however neither HDD came with drivers/disks so what do I need to do?
Vista supports most SATA Controlers by default, I know it dont for Silicon, and you need drivers to install Windows.
The HDD has nothing to do with it, you need drivers for the Sata Controler on your Motherboard so need make/model of that board.
When asked for the disk, use the drivers provided on the motherboard CD.
Vista is after the drivers for the controller on the motherboard, not the drivers for the hard drive(s).
The drivers on his Mobo CD may be really old, only he can find that out.
the motherboard cd when scanned just says no device drives were found, make sure that the installation media contains the correct drivers... :confused:
download on the laptop save to disk and then install on pc... ok will do that now ta! and its she not he :p thanks guys!!
I would one either of these 3.
Intel ICH9R Driver
or
GIGABYTE SATA2 RAID Driver
or
Intel ICH9R SATA RAID Driver
Presuming you have a 32bit Vista install.
well I downloaded the 64 bit versions last night and tried it and it didn't work vista told me again the required drivers weren't there :(
Sounds odd problem, one thing you may want to try (and this is guess work), is plugging the hard drives into the yellow sata ports on the motherboard instead of the purple.
Not sure why that'd make a difference, but my computer was a little uncomfortable at first in the (faster) purple sata slots.
Ofcourse its probably nothing to do with that and just a bit of a driver faff being kicked up from vista, in which case all you can really do is keep trying drivers :(
bleugh nothing is working! Ive googled it and it seems to be a common 64bit vista problem but no one way works for everyone :rolleyes: and I thought building the inside was hard :o
After downloading the driver from Gigabyte, you did expand or uncompress the files didn't you? Sorry to have to ask.
they are all raid drivers I'm not set up for raid could that be why the drivers don't seem to work for me? do I need to change something in bios?
