w00t PROJECT MODDAGE (Featuring Sarah the Red PC60) ;)
Nix said:
I honestly think that you should paint the power buttons black too. The silver clashes with the red too much.
It can be difficult to paint plastic without it looking tacky. I might give it whirl though :)
All this mod talk makes me want to do one of my own....just need a case now
Good work btw - nice to see a non-perfect job that still looks the business, gives hope to us all :D - are you going to respray the top??
Personally would have gone with the blue of your PSU - but I also like the contrast of the blue/black/red - keep the picks coming
I may well add another coat to the top to try and even it out for a better finish.
I do like the blue but i previously painted an antec super lanboy in a very similar blue. New thread soon with that!!! lol :D
The top looked like you were a little bit to close on some of your passes with the spray can - try standing back a bit, starting and finishing to either side of the surface (appoliges if you know all this) :D
If your lanboy was blue I can see why you went with the red. Thanks for the reply
Nix said:
I think the bezels may look quite nice in a slightly deeper red. What do you think?
Not sure on that, maybe ill take some more recent pics and then photoshop it to see what it would look like.
Yea, i think i wasnt going off each side of the metal because i was trying to be conservative with the paint. There is nothing in those tins and they arent that cheap!
Why did you leave the mobo tray silver?
Also i think you should go that bit further and paint the PCI brackets, fan grills and I/o panel red as well!
Forgot to say cracking go, as metioned nice to see something thats not perfect but that still looks good, shows anyone can have a go.
I have a 201 awaiting some sort of paint/mod job - all these posts are giving me nice ideas
I thought it would look nicer having some silver left on the inside and the same with the fan grills, i/o plate, pci brackets. Maybe i should have done a mr bean job. Just set fire to the paint can and evacuate the room. :D Have everything red, including the walls :cool:
Edit was required, edit or possible suspension, take your pick. ;)
No nasty yellow or anything, nobody would have known if you had not have mentioned it.
Red PCI plates would look killer though, only take a few minutes to do aswell!
