Yeah I know "media walls" etc are on trend at the moment but to be honest all you would be doing is reducing the overall size of the room which isn't what I want to do
Yeah I know /figured that's what you mean but my amplifier is deeper than that wall.
I presume you're referring to the sketch/annotation above? That's from someone else not OP (me) I'm not going with that built in option.tv's not going to reflect off of the top of the unit ? or speaker sides, if, as it looks, they stand proud. ... don't want it to look like a tunnel;
will the imaging from speakers be ok at that level they are (very imhop) close together & high
Used the Ikea floating cabinets for our chimney breast which is plasterboard straight onto breeze block so I just used normal plasterboard screws/raw plugs and hung each unit on 2 metal L brackets from Amazon I am terrible at DIY but they are solid even the full size end units which I cut the corners off are ok. https://forums.overclockers.co.uk/threads/what-man-jobs-have-you-done-today.18433753/post-36640056
