- 20 Apr 2004
- Rugby
with my old rig (see sig) + moniter speakers etc , +xbox360 it used to top out near 600w under load with cpu gpu and 360 maxed out now it dos'net even hit 400
chaparral said:40watts = About £43 a year for 24/7
So a system using 228watts at idle 24/7 would cost you about £186 a year in electricity bills...Not counting the power draw from the monitor & speakers etc
This is based on 12p per kw (This is not counting Low Rate Periods)
Just tested this...My dell 2405 uses 47watts went in use and only 7watts in standby...Dutch777 said:I’m sure I’ve read somewhere before that an LCD monitor still draws the same power when in standby as when it’s on, anybody confirm this ?
I tryed this loads of times but the system draw just drops to below 300wattscavemanoc said:have you tried Both cores and Atitool at max clock/voltage (could only find an either/or in the thread?) - I'm sure you can crack 400W![]()
chaparral said:Just tested this...My dell 2405 uses 47watts went in use and only 7watts in standby...
from what i was taught at college: (if i remember correctly)chaparral said:40watts = About £43 a year for 24/7
(Someone please correct me if these figures are wrong)
What the laptop specs and what the power draw on it ??MikeHunt79 said:Well, I have a watt meter, but no rig... I'm on a damn laptop right now.
As soon as I get a motherboard, I'll post some numbers!![]()
120W PSU for my lappy.... I've fixed my main rig now...What the laptop specs and what the power draw on it ??
I would test my laptop,,but i can't find the charger for it![]()
your only 105watts ide with overclocked Q6600 quadcoreI am currently on my main desktop, specs:
Q6600 @3ghz and stock voltage
DS2R G33 mobo
8800gt stock settings
2gb ram
2 x 320gb 7200.10 raid 0
My kilwatt meter reads 105watts idle, 190watts all cores loaded and 200watts on COD4
If you want more systems rated give me a shout, I have 2 laptops and two shuttles
