Was talked into a rimless toilet - nothing but problems.
Status
Not open for further replies.
It is odd, could have been something in the box I missed. My cistern was supplied with the toilet so you would assume they would work correctly.
have you sent a picture of install to manufacturer ... given all the stuff about pre-texts for exploiting consumer right in hi-fi section - this sounds a very legitimate claim
We had our bathroom redone and installed the Florence back to wall rimless toilet from soak.
When it was fitted, the plumber mentioned that the ubend outlet is very small and that the flush does not reach the front of the bowl. (He never fitted a rimless toilet before so wasn't sure if that's normal on these)
It is with a 6 litre cistern as supplied by the company
And yep sure enough every other "session" the bugger is blocked! and on top of that the front of the bowl is not flushed at all!
I have uploaded a short vid showing the flush.
The wife rang their customer support and they stated nobody else had a problem with this toilet and asked for videos.
Any experts here know if it is working as it should or a manufacturing defect ?!
Hi
Can you please show how your flush is working after fix
I've actually found some white rubber bungs on the bay that I'm going to use instead of silicone for a slightly better and lasting solution
Hey
Can you please share the link for rubber bangs
I got same issue to my florance rimless toilet
Status
