water cooled corsair 600t
awesome yellow and very nice build
you think your fingers are sore after compression fitting.. you gonna love braiding
one thing that confuses me though... when I saw the pics I thought it was a 800D but I see the topic is 600T... how have you managed to fit the fans and the rad up top without obstructing the motherboard? does the 600T have more room up top? do you have a very thin radiator?
the rad is quite small compared to most, only being 30mm thick....its the magicool rad....and as you can see theres only millimeters to spare between the rad and the motherboard.......the 600t also has a compartment on the top of the case where you can install 2 x 120mm fans and they are hidden....so you cant see them unless you remove the top , which is just simply clicked into place......you definately couldnt use push pull configuration up top, but seen as its a thin rad you probably wouldnt gain much anyway.....
as for temps...these are just idle temps at the mo so will do some playing later and report underload....
gpu 1 27 degrees
gpu 2 29 degrees
cpu 23 degrees average acroos the 4 cores
is that a custom panel i spy? if so, can we know how you did it please? :)
hi there, yea its a custom panel.....dont have any pics from doing it though as it was done around 18 months ago or so.........so this will probably sound a bit vague.......
how it was done was:
placed masking tape over the front of the panel, all over the complete area.....i then drew a rectangle....cant remember the exact dimensions, then set up a compass to draw in the quater circles.
from here i drilled a hole to allow the jigsaw blade to cut the panel out.....
once cut , i then had a template for the perspex sheet...... placing the cut out on the perspex sheet i drew the same shape on the perspex.......I knew exactley what the dimensions were of the edging strip and took this off the perspex...to make the perspex window fit nice inside the edgeing strip....the perspex was cut with the jigsaw aswell , but beware, the quicker the blade goes on the jigsaw, the more you a likely to melt the perspex rather than cut it.......
once cut to size.....i placed the edgeing inside the case and fitted the window inside the edging strip......then put the insert in which stops it all falling out.....
this is the edging strip that was used :
images
these are the only pics i have of the side panel.....
yep, i did almost the same thing, but what i really want to know is: how does the perspex fit? the panel isnt flat so is there a little warping? are there air gaps? or does that rubber hold it well enough? :)
its very sturdy....the rubber egdeing holds it quite well........its never fell out, but i would say it you pushed on it hard , it may come out.......there are no air gaps......and i wouldnt say its distorted at all.......the panel has a slight curve in it , but it curves quite a lot towards the ends on both sides, roughly inline with the top catches.....and not so much in the middle part , so i avoided that part of the panel when i measured it up.........
was really looking to get some pre braided cables :o in yellow and black......
but looks like im going to have to do it as it doesnt look like you can buy pre- made black and yellow braided cables.....
if you buy the stuff from XSPC at least you can braid all cables, including the IO ports, your lights etc.. the pre braided calbes only do so much...
@ stueng...will have to take a look, think it will look better aswell if i do it myself, rather than going for a colour i dont like.......
@Ary101....never really totalled it all up......but inc monitor , mouse and keyboard...possibly close on £2.5k spent.....blummin hell it gave me a shock.....i know folks spend a hell of a lot more.........
i'd recommend cpu-id so you can see on one small window the frequency and voltage changes while u overclocking.. as you increase LLC to obtain stable overclock your voltages will suddenly spike quite high and you wanna keep an eye on this
