maybe .... thing is its good to have some air flowing over the components regardless ..having said that, I did turn all my case fans off in an experiment, and noticed no significant difference in temps ... but as my case fans are virtuallty silent at 12v (with the exception of the 92mm rears which run at 7v and are then silent) noise is not an issue TBH.
A radiator will certainly need some fans if you have a high end system, but a Thermochill PA120.3 with low speed yates @ 7V is near silent.
I chose my PSU for the combination of noise and stability, and have to say I feel my system is as quiet as you can get without having an entire passive system .. and better temps than air to boot
I thought my aircooled system was quiet, but compared to this setup, its was a jet engine
For the record my case has 3x120mm aerocool low speeds @ 12v, and 2x 92mm Antec tricools @7-8v with the 3x yate loon DSL12 low speed on the rad @ 7-8v, all controlled by rheostat Sunbeam controller.
I mounted an Evercool VC-RE cooler on the SB (thanks to someone on these forums for pointing that out) that is running @ 50% in mobo bios.
waste of power if you ask me lol.
