Hi,
I purchased a complete custom PC (£1500), pre-built, from OC about 3 or 4 years ago, but I've had my first fault, that appears to be the water cooling system, and wondered if anyone could help!
My PC's CPU / water cooling fans ramp up very high and stay that way, about 2 minutes after first switching on the PC, and the performance is thus very poor, due to the CPU temperature reaching 90-100'C.
The cores are not being driven hard (see pic below), as the PC is just idling, and all fans are working, so there is either a blockage, or the component on the CPU itself (pump?) has failed.
I had this problem about a month or so ago, and it fixed itself after about a week, after a unplugged and reinserted the CPU fan connector, cooler connector, and gave the rubber pipes and good waggle, but I think that was just coincidence, maybe?
There is voltage (+12V, and voltage on the speed sensor / throttle) too.
I have no idea what the cooler is, as there is no branding, and the purchase invoice is missing this component.
The MB is: MSI Z97 Gaming 5 Intel Z97 (Socket 1150) DDR3 ATX Motherboard
The CPU is:
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150
Processor - OEM
Has anyone else had this or have an idea on how to fix it?
If nothing can be done, I'll need a new part or worse a whole new cooling system, but I have no idea what it is or what I need to ensure compatibility.
Photo of cooler is here: https://www.dropbox.com/s/m6p3dvpu61f5co8/20190206_181206_resized.jpg?dl=0
Screen grab of stats here: https://www.dropbox.com/s/a1j8gglfnbx2b3s/Screenshot_20190206-181305_Arx Control.jpg?dl=0
Many thanks!
Phil
The CPU is:
Processor - OEM
Many thanks!
Phil
