The other day i installed all my water cooling gear, which consists of: Danger Den 5 1/4" bay res, Danger Den Maze 4 VGA Block, Thermochill CPU Water block (with 1 intake and two outakes) Danger Den CSP-MAG pump, and a 120.1 rad (all with 1/2" tubing) and it doesn't seem to be doing anything! The temp just keeps rising until it over heats and turns off. Bit puzzled as to whats happening. All blocks were applied with AS5 and the lopp is as follows: res>pump>rad>VGA block>CPU block>res. Am using PC Ice water. Can any one guide what i can do to fix this/change to get it working. Thanks in advange.
