Hi have a few questions about water cooling. I have chosen the following things
mountainmods Extended Ascension
Koolance CPU 360 Rev1.2 CPU Waterblock Intel 1366, 1155, 1156, 775 AMD AM3, AM2+, AM2 : CPU-360
XSPC Dual Bay Reservoir with DDC Ultra 18W Pump
PrimoChill ICE Non-Conductive Coolant (32 oz.) - Blood Red
XSPC 7/16" ID - 5/8" OD (11-16mm) High Flex Tubing : Clear
Heavy Duty Hose Cutters
Plastic Funnel - Ideal for Watercooling
1000ml Squeezy Bottle for filling Watercooling Systems
But I have a few items left to pick one of them is the radiator 480mm Quad for 120mm Fans
So what the best radiator 480mm Quad for 120mm Fans???????
I also need to buy some fans for the radiator and case fans know I was hoping to buy some very low noise fans with led red so may I ask what’s the best radiator 120mm fans?????????
And what’s the best 120mm case fans???????????????
Also in this video
in 19.24
Tom says you need a paperclip instead of a buying a tool well I don’t like the idea of the paper clip so can some tell me what’s the name of the tool that he is talking about?
Also I heard if you get dust in your system that it would then be conductive is this true?
If this true then will this destroy my gear??????
Also in this video
