- 24 Dec 2010
- Surrey
Watercooled 650D - ENVY
The components:
CPU: Intel i7 4770k
Motherboard: Asus Sabertooth Z87
RAM: 2 x 8GB Corsair Dominator Platinum 1866mhz
GPU: Palit Nvidia 770GTX (X2 soon)
PSU: Corsair AX850
Boot drive: Crucial M4 512gb
Storage drive: Western Digital 1tb blue
Case: Corsair 650D
Fan hub: NZXT grid
Cooling: Corsair AF/SP 120 fans custom painted!
Watercooling equipment:
CPU block: EK Supremacy clean
GPU block: EK 770 waterblock
GPU backplate: EK 770/ 780 / titan backplate
Top radiator: XSPC 240mm cross flow
Front radiator: Alphacool NexXxos Monsta 240mm
Resevoir: XSPC dual bay resevoir
Pump: XSPC D5 and pump top combo
Fittings: XSPC g1/4 black chrome fittings
Tubing: Normal green tubing
Coolant: Green coolant of some sort.
Styling:
I have been braiding the cables of the power supply a lovely green colour. I have now moved onto the case cables. these will all be braided green. - ALL BRAIDED
I will be painting the rings of the SP/AF 120 fans green to match with the build. - ALL PAINTED
I will be cutting a hole in the front of the case to accommodate the 240mm radiator which I will be inputting into the build.
The components:
CPU: Intel i7 4770k
PSU: Corsair AX850
Case: Corsair 650D
Fan hub: NZXT grid
Styling:
MY GOD! That Radiator's a Monster! I'm looking forward to seeing this come together. It looks so weird with the standard Intel Cooler fitted, 98% of the builds on here have aftermarket coolers I'd almost forgotten what the OEM ones look like. I bet you can't wait to get everything plumbed in and get the EK blocks on there. Great work, oh and the cable braiding looks spot on you should be well chuffed with that
