omg. it aint a good day for you, is it?
Do you think I have any flow issues in here? lol.
Right now I need an angled fitting, just 1 extra fitting, I would take any angle at all. Overclockers is a two and a half hour round trip away, almost worth it at the moment. 1 piece from being finished.
Dont worry the kink is gone. It was just to illustrate my problem really.
As it looks like it is going to be Tuesday/Wednesday before I can get the pump issue sorted it gives me a few days to get together some bits that I could use. I have ordered a few more angled fittings, so that will help on that front. I have also ordered some white acrylic and white carbon fiber wrap. Hopefully I can find a way to blank off the two sides of the psu, and perhaps even make a small extension to cover the mobo power cables. Not so sure about that last bit mind.
Anything else anyone can think of? I have a few quid in my paypal i can use on the bay if needed. So open to suggestions.
white 140mm fan for the back!
maybe couple fan filters for front? or not worth it?
