WC-what liquid?
26 Sep 2010
Hay May Land
I have done my first Wc pc everything works fine but the colour of my collant has changed from bloody red to bright cherry.Can someone tell me if i can use a anti freeze and coolant from halfords for cars?.This color looks awesome.Its a orange-purple.Would that be ok to use in wc setup or it can make some harm to components?
No l would use distilled water + silver coil + coloured tubing, l think you can but its got to be very weak solution, personaly l wouldn't take the risk as its designed for a car engine.
it's probably thicker too, may damage your pump. distilled water + silver coil + coloured tubing for the win
Ok i won't use it.Does enyone has opinions about Feser One coolant,it seems to have a nice colors and when is Uv it gives a nice effect.
Yeah, there are opinions on feser one. Not positive ones.
Where do you think the red dye that used to be in the liquid has gone?
Do you think that this will block blocks of lower the flow?
No, I think it already has. It's a learning curve, loads of people buy feser one once. Strip down the blocks, get a toothbrush out, and see how long it takes before you decide coloured tubing is the way to go.
Been using antifreeze for 7 months now without any issues, I will get round to changing it for some distilled and PT nuke at some point
It was a bottle of 50/50 bluecol premix with some Mayhems UV purple Dye in it. No staining or any floating particles as yet either.
I have feser ultra pure water plus primochili but after few weeks my hoses aren't clear any more,purple i can say/ ;(That's why i am looking for alternativ coolant. I has to be red because my motherboard got red logos.
