WD 3tb External Help
1 Dec 2003
Liverpool
Hi guys,
Bought myself one, i already had a 1tb one which has been great, though slowish transfers, around 1 - 12mb max to transfer from laptop - external.
Anyway, my 3tb one, when i plug it in the main it comes on right away, when i put the usb into a port, it is taking upto ten mins to show up as a explorable/open-able drive in 'My Computer'. Which seems outrageous? Considering my 1tb takes seconds
Anyway, once and IF it eventually allows me to use it, i am getting 12kbps - 2mb transfer rates, so to send for example a DVD ripped movie to the drive from my Laptop, its taking literally hours!!
Any ideas what i can do? I have done the official WD drive tests and all come back ok.
Thanks
Chris
Just a couple of questions - have you tried it with another PC, and how does the drive show up in disk management?
Hi,
Same result in another two computers,
shows up in Device Manager.
Disk Management; it is showing now (after ten mins of being plugged in) as:
  • basic
  • online
  • New Volume
  • (i) Drive
  • NTFS
  • Healthy
Yet; if i unplug it, just the same, 10-15 mins to recognise in my computer (USB 2.0 & 1.0) and then extremly slow transfer rates, hours for a movie, so i have yet to bother putting anything at all on it.
Hi, well if it does it with several pcs I'd be thinking there was sonething wrong with it.
Did it come ready formatted? Is it worth repartitioning and reformatting to see if it makes any difference? I'd also have a look in the windows event logs to see if there were any clues there.
Okay,
Events, i plugged it in, refreshed and see these two. Any ideas?
1) An error was detected on device \Device\Harddisk3\DR3 during a paging operation.
Source; disk
2) The system failed to flush data to the transaction log. Corruption may occur.
Source: NTFS
Not sure about those I'm afraid. If you double click on them it should show you an event ID and allow them to be looked-up online.
Maybe a long-shot, but is this a USB3 drive? I've seen reports of driver problems with some chipsets, but this seems unlikely if you've tried it with several PCs.
No, it is USB 2.0.
It is the 3tb elements one.
I am currently reformatting so will let you know. I tried the online ID search but no luck with that.
HD Tune results;
Benchmark
Transfer Min: 0.00MB/SEC
Transfer Max: 17MB/SEC
Average: 2.1MB/SEC
Info
This tab is completely empty for some reason?
Health
Empty, says N/A
Error Scan
Completed says; 0.1% damaged blocks. The rest shows as okay.
What does this all mean and any other ideas etc?
mmmm, I'm getting a paging error on my 3TB disk (or should I say disks as I have the same error on both). These are internal though, not external.
Google shows up TONS of issues with 3TB drives.
HD Tune results;
Benchmark
Average: 2.1MB/SEC
Info
Health
Empty, says N/A
Error Scan
MMM, new with damaged blocks :/ doesn't sound too good mate. I would take it back if you can! If not set up a return to WD for replacement.
The slow transfer speeds make it sound like the controller board in the caddy is borked
Well, the fountain of knowledge, wikipedia says:
Count of "unstable" sectors (waiting to be remapped, because of read errors). If an unstable sector is subsequently read successfully, this value is decreased and the sector is not remapped. Read errors on a sector will not remap the sector (since it might be readable later); instead, the drive firmware remembers that the sector needs to be remapped, and remaps it the next time it's written
http://en.wikipedia.org/wiki/S.M.A.R.T
I'm not sure if this is a symptom or a cuase of you issues but I would contact WD and ask thier advise on the matter. You have proof that its not working right!!!!
I would be looking to have the drive replaced too, either by the retailer or, failing that, an RMA with WDC.
I've used the WDC advance RMA for internal drives a couple of times and it went pretty smoothly. I don't know if they offer this for external drives but if they do it solves the problem of finding suitable packaging.
