WD Red Raw Read Error Rate
4 Jul 2006
For the past few weeks ive been seeing changes in Read Error Rate on my WD Red drive, I have contacted WD and they didn't seem overly concerned but said they would replace the drive
"As per the screenshot you have shared it shows that the drive Health and status is good, it shows that the drive is fine and can be used. If you still don't feel comfortable using the drive I can surely get the drive replaced for you as it still has a valid warranty."
This is the drive currently now
I have never seen a fluctuating RER rate and I got 2 other WD Red drives at 10TB that are fine.
Sometimes the info resets and it says current/worst is 100 and raw value 0 despite the worst being 94 before when I ran a virus scan on the drive (Done as a test to see what would happen, it went up into the 2-3mil raw value and went to 94).
Considering its still reporting good and there are no seek/reallocation changes how concerned should I be? The first time I am seeing this issue on a 12TB drive since its my first 12tb drive and despite a screenshot showing this
The history of said read error rates keep resetting as you can see here.
Edit
Just swapped SATA cable for a new one I had in packaging still, same result.
When you did this:
When you did this:
I did it after you posted to do it, I shut down PC and done it.
Check the images, in HDSentinel you can see that the history is resetting to 0 for smart results over time.
For the reset in HDSentinel check the image I sent to WD then the image under it
Just running a virus/malware scan on the drive will make the raw value go up but hte other two 10tb's don't exhibit this behavior.
