Caporegime
- 22 Oct 2002
- Boston, Lincolnshire
Forget about the MX5. The Mk3 MR2 with a 2ZZ has it trumps and will offer that caterham/elise feel.
1k for a Corolla/Celica with the 2ZZ engine and MK3 MR2 will set you back 1.5-2k(<1k if you buy a mr2 with a blown engine). Plus around 1.5k for the build. That includes all the little bits like LSD for the gearbox and the custom parts required for the swap. You would also make back a bit if you put the effort into breaking the donor car. You could maybe even squeeze a rotrex on top of your budget.
There are companies that can source everything you need and you supply the base car but obviously that is more expensive but still easily done with your budget.
That would give you top of the range Exige S power levels for very little money and blow any MX5 turbo car out of the water!
