Weird problem on Windows 10 10240.
23 Oct 2012
So i started having this problem yesterday and thought it may of been my GTX 980 or something related with drivers for it, so uninstalled them and reinstalled them all but still didn't fix it.
I reset windows 10 install back to default, so nothing was installed only windows 10 as a "clean" install. Now this problem isn't permanent and only occurs occasionally but its really annoying, it also worries me because it could be my GFX card dying, which is only 3 months old.
Heres a video (not the best but you get the picture)
As you can see it onlt lasted until i closed the window and reopened a new one.
So does anyone get/had this and does anyone know what causes it?
had that when i first launched diablo 3, turns out it was a windows defender popup and once closed and restarted I never saw it again
do you have another gpu to test with and take it your on the latest NVidia drivers?
do you have any oc on the gpu and is your bios up to date?
No overclock on CPU or GPU, and i've not seen a pop up from windows defender so not sure its that.
I only have on board GPU. Intel HD 4000.
