well im trying to help from a laptop tucked up in bedbut I'm getting up now
Really good of you.
I am going to try the mod again is there a difference between Original 2010 gameplay and None?
<?xml version="1.0" encoding="UTF-8" ?>
<hardware_settings_config version="46">
<cpu>
<threadStrategy parallelUpdateRender="true" workerMapFile="system/workerMap2Core.xml" forceFeedbackProcessor="1" dvdStorageProcessor="1" dataSetMonitorProcessor="0" renderProcessor="0" updateProcessor="1" fileStreamProcessor="1" />
</cpu>
<audio_card>
<audio mixing="software" reverbs="4" voices="100" />
</audio_card>
<graphics_card>
<directx forcedx9="false" />
<resolution width="1920" height="1080" aspect="16:10" fullscreen="true" vsync="0" multisampling="8xmsaa" oldWidth="800" oldHeight="600">
<refreshRate rate="60" />
</resolution>
<gamma level="1.0" />
<textures lod="0" />
</graphics_card>
<graphics_detail level="high" />
<shadows enabled="true" size="2048" maskQuality="2" />
<headlights headlightQuality="2" />
<particles enabled="true" wind="true" />
<crowd enabled="true" detail="1" />
<cloth enabled="false" detail="0" />
<postprocess enabled="false" blur="false" quality="1" />
<groundcover mode="atoc" clutter="false" />
<objects lod="1.5" maxlod="0" />
<trees lod="1.5" maxlod="0" />
<vehicles characterQuality="3" lodQuality="3" />
<envmap faces="6" size="1024" forceBilinear="false" />
<water update="false" detail="0" />
<mirrors enabled="true" forceBilinear="true" width="256" height="64" car_maxlod="4" car_culldist="100.0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" />
<track_reflections enabled="true" />
<physics environmentalDamage="true" vehicleDamage="true" />
<motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0" />
<track_info_system type="gpu" />
</hardware_settings_config>
<hardware_settings_info>
<systemInfo OS=" (Build 7600)" totalMemory="4193376" winPlatformID="2" winMajorVersion="6" winMinorVersion="1" isWinXP="false" isWinVista="false" isWin7="true" rating="4" />
<cpu name="Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz" speed="3001" cores="2" hyperThreading="false" sse2Supported="true" rating="3" />
<graphics_card name="ATI Radeon HD 5800 Series " vendorId="0x1002" deviceId="0x6899" vs_shader="3_0" ps_shader="3_0" memory="2805" rating="4" dx11="true">
<resolution width="640" height="480" aspect="normal">
<refreshRate rate="59" />
<refreshRate rate="75" />
</resolution>
<resolution width="720" height="480" aspect="normal">
</resolution>
<resolution width="720" height="576" aspect="normal">
<refreshRate rate="50" />
</resolution>
<resolution width="800" height="600" aspect="normal">
</resolution>
<resolution width="1024" height="768" aspect="normal">
</resolution>
<resolution width="1280" height="720" aspect="normal">
</resolution>
<resolution width="1280" height="768" aspect="normal">
</resolution>
<resolution width="1280" height="800" aspect="normal">
</resolution>
<resolution width="1280" height="960" aspect="normal">
</resolution>
<resolution width="1280" height="1024" aspect="normal">
</resolution>
<resolution width="1360" height="768" aspect="normal">
</resolution>
<resolution width="1400" height="1050" aspect="normal">
</resolution>
<resolution width="1440" height="900" aspect="normal">
</resolution>
<resolution width="1600" height="900" aspect="normal">
</resolution>
<resolution width="1680" height="1050" aspect="normal">
</resolution>
<resolution width="1920" height="1080" aspect="normal">
</resolution>
<capabilities a2r10g10b10="true">
<alpha_to_coverage supported="true" method="ATi" />
<multisampling>
<mode name="off" />
<mode name="2xmsaa" />
<mode name="4xmsaa" />
<mode name="8xmsaa" />
</multisampling>
</capabilities>
</graphics_card>
<audio_card audioEnabled="true">
<unsupported type="hardware" index="0" voices="0" />
<mixing type="software" index="1" voices="192" />
<mixing type="rapture3D" index="5" voices="192" />
</audio_card>
</hardware_settings_info>
Also turn off afterburner !
