Take the better screen![]()
I'll run it past the CO tonight and see what she says
I get 7% off vouchers so if I got this through Currys it would be about £882.
So it seems tcb have a 10% exclusive for Currys.. makes it 855 as far as I can tell!!!
From what I can gather the KD49XE8004 is a set 100hz, but the KD49XE8005 is 50 but uses motion interpolation yo push that to 200hz. So what is the difference between a baseline of 100hz vs a baseline 50hz with the 200hz interpolation? Does that mean I'll be better off with the KD49XE8005 opposed to the cheaper KD49XE8004 which is funnily enough newer than the more expensive model. Other than that I can't see a difference between the 2 models.
What I do know is this is in my house now
Cant see the pics, what did you go for :x?
according to hotuk and https://www.avforums.com/threads/buying-a-sony-43xe8004-or-sony-43xe8005.2135700/
they are both 50Hz, as apparently, is the mu7000, but not xe9,
so conventional black frame insertion (alternating with the 50hz freeview/sat frames) is not available, which might help with action sports/football viewing, or higher fps gameing.
they have 100hz/200hz backlight scanning instead
So
So what's it like? What sources are you plugging in?
