You can waste all the time you want, you're not going to get a decent tyre fitted for £50 on a Focus because that's exactly the car I have now and I'm having to spend £75 a corner to avoid buying rubbish - Hankooks are £70 a corner fitted.
Most Mondeos will have 205/55 R16 which cost the same as 195/60 R15 fitted on the Focus. Oil and filter the same, brake discs/pads the same etc. All that stands is insurance, the difference is negligible for some people (insurance for me is odd because I live in the UK equivalent of Basra) and you spend £5.80 a month extra on VED. So all you have to deal with is a tiny increase in fuel consumption but you get a newer generation of car with more power and more equipment. You'll also get a newer car because Focuseseses (Foci) tend to hold their value slightly better as they are in demand whereas everyone is scared off by a 2.0 Mondeo because they think it's the size of the QE2 and has fuel consumption measured in gallons per mile when that isn't the case.
) , more comfortable, better speced car for a negligible increase in running costs. In fact why someone would choose a Focus over a Mondeo at this price point unless they quite literally for the life of them could not get insured on the Mondeo is beyond me. You can waste all the time you want, you're not going to get a decent tyre fitted for £50 on a Focus because that's exactly the car I have now and I'm having to spend £75 a corner to avoid buying rubbish - Hankooks are £70 a corner fitted.
Some people here would have you believe it was the defining car of our Generation, not simply an above average medium sized hatchback.
My zetec had heated windscreen and AC as did my brothers - I thought they were standard?
Yes, my lack of illumination ability clearly makes me in no position to comment on car recommendations for someone asking for car recommendations.
Thanks for reminding me.
I think you'll find it was quite special in it's time for styling, rear suspension setup and price.
I bought a focus over a mondeo because I wanted something smaller than a mondeo - I didn't want any more toys other than elec windows and AC- ended up getting heated windscreen and mirrors, electric mirrors and remote central locking as part of the bargain - for £950 I think the focus was a pretty sweet car.
If you dont need the space the Focus is the better option.
Mondeo will definitly cost more, to buy and to run and maintain,
My 53 plate zetec focus had neither AC nor heated windscreen. So was not standard option
Exactly.
to buy
and to run
and maintain
if you dont need the space the Focus is the better option.
The mondeo needs the 2 litre minumum,
Just looking through some classifieds it seems there is quite a decent choice of 2006 Mondeos for 2-2.5k, but only utter dross in terms of the Focus (e.g. non-runners, write offs, huge mileage etc).
