I have the Torrent Compact and its the front 180mm fans which make an annoying ticking noise. Not isolated which fan it is (may be both). It does go away when the fans are ramped up but I typically run them at 20-30%.The 140mm fans on my Torrent make an annoying ticking if you run them at less than 45%, it's pretty quiet at 45% though. The 180mm fans are both fine no ticking from them.
I've currently got a 13600K and 3080 fitted, will buy a 4080/4090 later. I restrict the fans to run at 60% max and everything runs cool.
The 7000D is a beast. The solid side panel alone weights more than most mid size casesGot the 7000D at the weekend.
Massive (and stupidly heavy) case.
It makes the 4090 look normal sized.![]()
.Im hoping it eases or goes away over time. It’s not there all the time at the moment.The 180mm fans are pretty silent in my Torrent, they were also silent in my Torrent compact too.
I'm just in the process of replacing the 140mm fans in my Torrent with Noctua NF-A14. The ticking at slow speeds with the Fractal 140mm was just too annoying.
Its only one of the fans doing it. I’ve raised a ticket with them.My Torrent is really quiet now after replacing the bottom 3 x 140mm Fractal fans with Noctua NF-A14 today. I'd contact Fractal and get the 180mm fans replaced as they shouldn't have any ticking.
2 of the 3 Fractal 140mm ticked in my Torrent when running at less than 45% ish. I have an older Fractal case with the same 140mm and they are silent guess I just got unlucky with the torrent.I don't hear any ticking.
Same here. They sent replacement fans which were better. Slightly humming because they are too close to some metal bits from the bottom fan bracket. Made the Torrent much quieter using some 5mm spacer for the bottom fans. But more to do with me being really pick than actually an issue.2 of the 3 Fractal 140mm ticked in my Torrent when running at less than 45% ish. I have an older Fractal case with the same 140mm and they are silent guess I just got unlucky with the torrent.
