Overclockers?Anyone know where I can buy spare O-rings for these DDC EK water pumps?
Overclockers?
Google it.I can't seem to find one on overclockers. It's the first place I looked.
First thing I tried. There doesn't seem to be any info out there on this. Daft isn't it? Seems the only way to get the correct spare O-ring is to buy a new pump.Google it.
EK have their own online shop.First thing I tried. There doesn't seem to be any info out there on this. Daft isn't it? Seems the only way to get the correct spare O-ring is to buy a new pump.
With a i9 and a 2080ti extreme I went for extreme cooling.Why so many rads?
Plenty of places to buy o rings....
https://www.polymax.co.uk/o-rings/rubber-nbr-oring/
https://simplybearings.co.uk/shop/Seals-O-Ring-Seals-NITRILE-O-Rings/c19_4501_4705/index.html
Theres two for a quick example. Remove the o ring from your DDC, measure and order from sites above
How important are heatsinks for DDC pumps? I ask as I have 2 that have been in my system for 10 - 15 years, neither have a heatsink and only one has had a fan blowing on it for the last six months or so. Not had an issue with either and both are still going strong.
EDIT - Just googled Laing DDC o ring size and multiple sites appeared listing a o ring to fit the DDC. Cant link them though as they are competitors.
