I asked YOU those questions in post 14 and you didn't respond. Avoiding the issue sometimes means that theres something to hide.Please don't talk about me in the third person, Please ask ME these questions, In answer to your "questions", Firstly i have the money to rectify the issue assuming it is the sensor as "my mechanic" also said replacing the DPF 10 months ago would fix the problem but now same error code, How much money should i keep spending on a car i am going to get rid of very soon for a hopefully more reliable car?, I meant i don't have the funds to spend on repairing this car and maybe should have stated that more clearly so my bad on that.
Secondly the remap was to me a better financial option if i were to rectify this issue, There is a garage near me that will remove DPF and fit normal through pipe and reprogram the ECU to bypass the DPF completely for £250, This would hopefully then solve all issue's with the Anti Pollution fault.
Also i am not worried if it does not fetch a grand, I was hoping for a grand and if they offer lower then i will auction it myself.
What would you think was "not right"?
So if you got the remap you'd still sell it soon? How is that any less 'hoodwinking' than forcing a DPF regeneration and then palming it off on a trader?
You don't sound like you have much confidence in your mechanic anymore, why are you still using him?
Just your wormhole logic that seems to jump through dimensions with no reasonable explanation why.What would you think was "not right"?
The only time i would EVER expect to see "replaced x" on an invoice (other than a breakdown of the work involved in fixing a fault) is for example earlier in the year where i supplied discs and pads to a garage, and specifically asked them to fit them for me.
