- 18 May 2010
Hello,
So my 1600X build has been working flawlessly since release day, no OC of any kind just an XMP Profile running 3200 C16
This morning I go to boot it and it goes into a boot loop with no image, I start to troubleshoot it and remove memory at which point it doesn't loop it sits running with no image
I put one RAM stick in the first DDR slot and it boot loops again, I put the other RAM stick in the same slot and low and behold it boots, faulty RAM stick right? Nope.
I then try and get into the BIOS to remove XMP profile and I cant get into the BIOS, it simply doesn't let me in at all, just boots to windows.
I then reset CMOS, same issue so I remove the battery and then the BIOS responds and I can get in, the BIOS is behaving very strangely, I can move the mouse but as soon as I touch the keyboard it goes nuts, the image flashes rapidly or the keystroke sticks and the BIOS locks with that keystroke, very strange. No such issue in Windows so keyboard is fine.
I flash the BIOS but it doesn't resolve anything, same BIOS strangeness and same RAM issue.
I then decide to try different RAM slot, I try both sticks in the slot closest to the CPU and BOTH sticks will allow the PC to boot fine so now I'm completely at a loss.
Is it the RAM, is it the Motherboard or is it even the CPU?
I've spoken to OCUK and they have suggested to RMA the motherboard and CPU however I really don't want to get those back only to find there was no fault and its the RAM that's the issue.
Any thoughts on this appreciated. The thought of no gaming for a month is grim and I am pretty frustrated right now as I almost didn't buy this build in favour of buying a PS4 Pro I really don't have the time to mess around these days and it eats into valuable gaming time.
Cheers
Cheers
