Had a problem for a while now with my PC randomly crashing, screen will go black, the sound carries on for a few seconds and then cuts to a continuous loud buzzing. I posted about it a while ago and was told RAM or GPU. To be honest I've just ignored it for a while as it doesn't really bother me if it happens during browsing etc... but during gaming is annoying, so I've got two questions.
Is it safe to leave memtest running overnight? That way I can rule out the RAM. If it's the RAM then my next question doesn't really apply but anyway;
What would be an ideal sidegrade or upgrade at this point, I've only just seen that the RX5** are due out soon, I'm guessing they are just an update of the RX4** like the R9 290 to R9 390? I'll be sticking around the RX480/GTX1060 price range as the 1070 is a bit too much.
However I would like to change to a full water loop eventually, I know I could probably go for an air cooled 1070 at that stage but I'd like a silent running water loop, and if I went 1070 I'd also end up buying a more expensive monitor to match it.
It's also just occurred to me while writing this that the R9 390 is still under warranty, what would happen at this point since they are no longer on sale?
