Here is my problem.
My company is running a flaky old Windows Server 2003 setup which has a single core CPU and three 150GB disks its run out more than once and caused us to have to delete stuff. It is currently only used for exchange and a file server.
The problems start when I look into any IT project at work I am severly limited in what I can do. I want a back office system a Voip solution, an Intranet and space to store tons of scanning. We need to buy a new server but we have been quoted £5k+vat which is too much at the moment. Most of that is the Server 2008 licence and the cals. We have been getting buy using external storge devices etc but it can't go on I have to do something.
I want to consider an open-source aproach since it will be cheeper and less demanding on the hardware requirements
However I am not an IT guy, the chap that looks after the server and the folks at the maintance company are all Windows People so its going to be an up hill battle. I have been using Linux for about 7-8 years myself but not delved into the server side and rarly touch the command line.
Can anyone offer any advice as to the best direction for me to go, what the typical problems are with this sort of migration, compatability and that kind of thing. If you can suggest a particular solution RHEL, SLED/SLES, Xandros, MDK or what ever that would be usefull.
My main consideration is cost but it must be easy for us to administer as we have limited skills in the company when it come to IT.
Any help is apprecited
Phil
Phil
