What's the easiest way to clone a system HDD?
use the acronis bootable cd (have to pay to be able to make it -£25 for the whole product), from there, you can take an image of the laptop drive and save it say to a network location (not wireless) or a usb hard drive
then put the new drive in, and restore from network / usb hard drive using the bootable ccd
okay.
I just used Easy Migrate and it copied my c: drive to my new harddisk which is currently f: drive.
It's apparently made it bootable. But when my PC restarted, the c: drive is still the old drive and f: is still f:
How do I change it now to boot from the new harddrive where I have migrated too?
Edit:
Just tried unplugging the old hard drive and now the new drive does read as c: and is bootable. Yey!
But... if I plug my old drive back in, that comes up as c: again.
How can I now reuse my old drive? I cant delete the contents because I need it plugged in to do that & then it is the boot drive.
Grrr.
Last update for you, because I'm sorted now...
I moved the new harddrive to be in the first SATA port in the mobo.
Now it boots from this as c: and the old harddrive is f:
All done.
Cool.
To answer your question anyway, you could have booted up windows on the new drive as a f and then change the drive letter around in a few minutes.
