Hi chaps
This starts earlier in the year, basically my machine would fully boot up. It turned out to be the graphics cards, well I belive as I replaced the cheap graphics card to a r9 280x and the problems was solved! So thought nothing of it other than don't buy cheap parts
Fast forward to last month.
My asrock 990fx extreme 4 board started making 5beeps on start up and showing d6 error code on the debug.
I rma'd the card as I presumed it would be this as it was the problem last time.
I get the card back this morning along with a new case and same problem.
Now although the card wasn't replaced with a new one, I presume it was either fixed or nothing was wrong with it even though it went back to gigabyte for them to sort out.
Now the graphics card needs 600w and I have a 600w cooler master psu so could this be the problem, but I can't see it as the card and system has worked fine for 6months without a problem.
Other than this I can only think the board is at fault (owned it for 2 years)
I've heard pretty rubbish things about asrock aswell and the d6 error that's showing points towards the graphics card not being found.
I've tried different slots, with/ without the card, I've unplug all unnecessary parts to try and lower the wattage but to no avail!
This is twice in a year it's happened and I'm lost so any help would be good, do I look into getting a new mobo? I'm pretty confident the card is fine as overclokers and gigabyte wouldn't send it back if it didn't work.
I haven't got any spare parts such as a mobo to try the card and other parts in, and I'm skint since I've just bought the case.
The spec is in my sig but with a 280 r9
Enervating I want to upgrade to a corsair 1000w psu and a better mobo but I want to find the problem instead of just renewing a lot of parts
Thanks
Thanks
